Is it possible to create Slanted Curved wall??
So... 🙂
13 Replies 13
Yes, Very easily thanks!
How can I enter Slant Angle?
Either in the settings dialog box, or directly in 3D into the tracker box that pops up when you click on a node.
I can't choose angle
Try Suspend Groups and make sure you have only one wall 'segment' selected.
You may find the wall has split into several curved segments if you magic wanded a spline, for example, so you may have to adjust each segment separately.
Ahh, you didn't say you were in AC10 did you!!! (Put it in your sig!)
Proper curved slanted wall were only introduced in AC11. This thread discusses possible workarounds in AC10.
http://archicad-talk.graphisoft.com/viewtopic.php?t=14873&postdays=0&postorder=asc&highlight=curved+slanted+wall&&start=0
Hope that helps!
OK... Tnx anyway 🙂 I'll get 11 next week, maybe it's the best solution
Rod Jurich
Scrat wrote:
/.... maybe it's the best solution
Only solution!
Rod Jurich
Dwight
NOT AT ALL!
I made curved, non-vertical walls in AC 10 by magic-wanding arcs or splines using a very small magic wand segment length. This, with a custom profile and - uh, was it the wall tool or the beam tool????
Attached is a composition using the technique with some SEO fun - wall segment stands alone as an example.
Dwight Atkinson
