‎2010-11-10 01:00 PM
‎2010-11-10 06:14 PM
‎2010-11-10 06:19 PM
TMA_80 wrote:I went back to ArchiCAD
well, it had ( only for windows )
there was a plugin which convert Su surfaces into native archicad elements (slabs, roofs walls...etc) but Graphisoft has stopped its developpement from Archicad13 . so if you could access AC12 you could try to see if it work for you.
p.s: I'm glad you've succeded in making this shape in sketchup, now the question is: why you want to edit it in archicad? as for the time being it'd somehow difficult....
‎2010-11-10 07:17 PM
‎2010-11-10 07:21 PM
TMA_80 wrote:That seems to work thanks! I didn't know about the 'turn' either which is quite good.
when orbitig, do not click on blanck space as it could lead to the issue you have : to avoid this issue
When in perspective mode, go to ( window/toolbar/classic 3d navigation/look to ) and click on a point on the model ( ie a wall , roof..etc) and then, orbting will be around the point you've clicked on.
