Is it possible to join fills?
Is it possible to join 2 or more fills that are already drawn? I have a detail of an enlarged plan of a corner of a wall. It was made with composites and is now fills and lines!! Ugh!!!
Thanks,
Mcihele
3 REPLIES 3
Aussie John
yes Michele. As long as they overlap, select one of them & click on a line to get the pet pallette Select the add option, then magic wand the other fill. You need to delete the original fill manually.
Cheers John
[/size]
Petros Ioannou
To join two fills, select the first one click one edge with the fill tool select the "+" from the pet pallette and trace the second fill with the magic wand! Don't forget to erase the second fill. Repeat as many times needed. Can't think anything else now it is quite late here...
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
So you really don't add them. I still have to do more steps then I'd like but maybe someday they will make some improvements in the detail tool or wall composites.
Thanks anyway,
Michele
