Is that possible to create hidden frame curtain wall?
Hello, I try to define hidden frame curtain wall in AC 15, the hidden frame curtain have hidden window in the panel. After several day's try, I find it almost impossible. Is there someone have successfully make this, can shall some experience? Thanks!
3 Replies 3
I'm not sure I understand... but see if you get any ideas from one of these two older threads about invisible frames and butt-glazing (which has nothing to do with a body part, but is a colloquial term for the glass panels abutting each other):
http://archicad-talk.graphisoft.com/viewtopic.php?t=23821
http://archicad-talk.graphisoft.com/viewtopic.php?t=6637
Sorry for the misunderstanding, I've put another picture, the follow is a typical hidden frame curtain wall. Can archicad 15 curtain wall tools make this kind of ?
David Maudlin
xwantheaven:
To get the glass on top of the frame, make the frame depth and glass setback equal.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
