Is there a way to brighten the interior render of a room, without putting lights on?
Giovannino60
1) Is there a way to brighten the interior render of a room, without putting lights on?
2) To launch a rendering, I clicked ctrl+9, now with Archicad 23 this command doesn't work which keys should I click, without going through the top buttons?
Thank you
Erwin Edel
1.  Short answer: no.
If you don't want to add the whole lighting scheme (understandably), there are some 'general' light sources you can add to the scene instead. I recommend the sphere shape and position it behind the camera, to act like a flash or those fancy studio lights that a profesional photographer would bring to light a scene.
2. I don't think it is a default hotkey, but mine is F10. You can set these in your work environment.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
David Lukacs
Hi Giovannino,
You can use physical renderer and if you do so, you can 'brighten' your image with the F-stop/Shutter speed settings of the physical camera. In this case you will prabably increment noise level as well. Before you go to the flash direction what Erwin mentioned, I suggest you to put area lights (softboxes) to the windows/doors, this way the result will be more natural.
Rubia Torres
Hi @Giovannino60,
Regarding your second question, you can check the current shortcuts and personalize them here: OptionsWork Environment > Keyboard Shortcuts.
For more details: Archicad 23 Help
Best,
Rubia Torres
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
