Mats_Knutsson
Mentor
Is there a way to have props expanded in the info box all the time?
TGF thinking here . In the more BIM-oriented projects we work with I'd like to to have the properties expanded in the info box all the time. It takes too much time to click to open "Properties". When we can we use schedules but quite often it's manual work.
A floating modal palette would be gr8 as the info box might be too small to accomodate all properties with explanations.
/M
AC 25 SWE Full
1 Solution
Lingwisyer
Guru
Should put a link here to it as people do not always check wishes.
Go to post
5 Replies 5
Not possible, as far as I know.
Eduardo Rolon
This would be a great wish.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Mats_Knutsson
Mentor
Ok. I put it under UI wishes.
AC 25 SWE Full
Lingwisyer
Guru
Mats_Knutsson
Mentor
https://archicad-talk.graphisoft.com/viewtopic.php?f=24&t=62122
AC 25 SWE Full
