LeeJaeYoung
Is there a way to mark the columns in the wall?
AC27 on window 11
5 Replies 5
DGSketcher
Legend
There are a variety of floor plan column symbols in the Column Settings, these are also controlled by MVO.
Alternatively you could apply a GO to highlight the cut fill & boundary of the column.
LeeJaeYoung
1, For the mvo, that's all.
2. In GOC, only Fill can be adjusted.
3. Is LINE not adjustable?
AC27 on window 11
sknsnw9
is this what you're looking for?
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
LeeJaeYoung
It also doesn't show borders
AC27 on window 11
David Lukacs
You should change the building material of the columns. Also pay attention to the building material intersection priorities.
