LeeJaeYoung
Is it possible to disable finalize/cancel when using 3d cutaway?
It's small, but I'm too lazy to click finalize all the time...
AC27 on window 11
1 Solution
david_skogvold
Yes, after moving the cutting plane you can just hit Enter instead of clicking Finalize. (Just tested it in AC24, should work in other versions too..)
Go to post
9 Replies 9
@LeeJaeYoung, don’t be lazy and click finalize pls pls cuz really you have to otherwise the model won’t be cut.
AC 29 INT 4006/WIN 11
LeeJaeYoung
What does "pls pls cuz" mean? The translator couldn't translate it... ^^
I understand that your words have no way.
thank you ^^
AC27 on window 11
Pls is short for please and cuz is short for because so I mean please Lee press finalize to get your model cut, thanks to you.
ryejuan
The annoying part is that the finalize button is not consistent in appearing in the same location, end up you still need to look for it. 😆
WINDOWS 11 PRO
david_skogvold
I had the same problem before, it's frustrating to hunt for the tiny button that keeps moving around the screen for every time.
Then by accident I found you can just hit Return / Enter instead of clicking Finalize – made my life a tiny bit easier.
Hi @david_skogvold, you said just hit Return / Enter, that means pressing Enter or what? Sorry need to understand.
LeeJaeYoung
thank you so much
AC27 on window 11
david_skogvold
Great tip David, I was not aware of this neat little keyboard shortcut.
