Isometry in scale.
How to print isometry in scale?
See:
http://archicad-talk.graphisoft.com/viewtopic.php?t=35572
to get the isometric projection correct. To print to scale, a 3D Document (3DD) view provides the most flexibility I think. Right click the 3D iso view to create a new 3DD.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thank you very much, i was playing around and it seems that i was heading in the right direction with my axonometry settings, but i didn't know that i needed to create a 3D document for scale printing. Didn't do any test printing tonight but will try tomorrow and hopefully it will work. Thank you again!
Edit: Worked like a charm, thanks again
