2025-10-01 10:37 PM
I’m trying to create a simple cladding made of vertical slats with fixed spacing. However, when the Reference Line changes direction (e.g. at corners or curves), the spacing shifts and is no longer consistent.
I disabled all components except the Balusters, which I’m using as the slats.
What settings or method should I use to keep a constant spacing regardless of the Reference Line geometry?
Solved! Go to Solution.
2025-10-02 12:10 AM
need to add an inner post with the same profile as the rest of the balusters.
2025-10-02 02:14 AM
Or maybe try with just posts and no balusters.
2025-10-02 10:35 AM
Yeah, just use Posts and set it to continue pattern between nodes.
2025-10-02 12:10 AM
2025-10-02 02:14 AM
2025-10-02 10:35 AM
