SOLVED!
Issues with building material priority in 3D window
Why would the building material "2x wood frame" with a priority of 683 extend over building material "Masonry - structural" with a Priority of 750 in a 3D window but not the 2D? They are on the same layer.
Archicad 22.3006
macOS 10.13.6
1 ACCEPTED SOLUTION
Solution
David Maudlin
nsgreen:
For the "Masonry - structural" wall, look at its settings > Model > End Surfaces: Override using Adjoining Walls, this should not be checked.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
2 REPLIES 2
Solution
David Maudlin
nsgreen:
David
wonderful!
Thank you David
