Issues with controlling objects in 3D view
Suddenly appeared problem with controlling things in 3D view-mode.
When I enter into 3D, everything is ok but I can't control nothing there.
No orbit, pan, explore, nothing. It will capture the picture and in 2D mode I can add and remove objects from my work.
And this problem is related to only one specific work.
When I open any other file or start something new, everything is OK.
Does anyone have any ideas why I have this situation?
Best,
Roland
3 Replies 3
Erich
It sounds that you have no movement options in the 3D window.
I am not sure if this is the same thing or not, but I also have a project that does this. I have found that if the first thing I do is to zoom to fit the window then all controls are restored. I have not yet identified the cause of this behavior.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Link
This may seem like a silly question, but I've seen some silly things in my time.
Are you sure you're not in a 3D Document window?
And have you tried both the perspective and axonometry 3D windows?
Link.
I was in perspective view
I changed it to axonometry view and everything became clear for me.
Thank You from thinking with me.
Best,
Roland
