Lack of simplicity in 3d modelling
Why isn't there a 3d modelling method that allows the user to model complex objects in a simple way? (like in sketchup). Archicad is much too literal in the way its library parts are set up, it lacks simplicity! Modelling a complex roof form is a nightmare (mesh to roof is in no way up to standard!), sloping a beam always seems to be tricky (if anyone knows how to model a sloped RHS, please let me know, thanks) - these should be basic fundamentals of an architectural modelling program!!!
13 REPLIES 13
Link
Use a complex profile with your beam.
Most of these things just take a little know-how and advice.
Link.
TomWaltz
not to mention, Archicad is made for making Construction Documents, which really need to be exact!
Tom Waltz
Thanks link, I'd already used the complex profile tool, but found limitations. I was able to model the beam in elevation and then extrude it to give the right width, but in cross section, is it possible to show the profile of an RHS? (rather than a solid rectangle)
As I said, this should be a very simple task, you shouldn't need advice or know-how to model such a basic object.
Dwight
Yes. It is a basic fundamental that users learn how to do these things with the sometimes sorry workarounds that exist. I sympathize with you that not all functions are fingertip functions and that many things can be improved.
Archicad is literal because it deals with the back end of creating basic architecture, not the kid stuff.
I wish architecture was all malleable plastic like in SketchUp but buildings are sticks and users must invest time learning and building elements.
Dwight Atkinson
not arguing with that, but Link is right, if you are using a custom profile for the beam, it will look as a steel profile in the section- not just as a rectangle
Link
It is very simple, you just need to learn how it's done in ArchiCAD. You wouldn't expect to drive an 18 wheeler, just because you know how to drive a car would you?
A beam like the one shown will cut it's profiled shape in section. And it's a 3D element, so it doesn' matter where you cut it!
Link.
Sorry, I don't know what you mean by 'not the kid stuff'.
I don't think that a sloped RHS can really be put in the same category as 'malleable plastic architecture'. What I'm trying to achieve here is not up with the fairy's, it's just a sloped RHS, which should be a very simple task.
It would just be nice to be able to have more flexibility to create editable 3d elements.
although, arguably Sketchup shows how easy it is to make objects and Archicad IMO will have to incorporate this style of modelling components eventually.
Just as an alternative, you could use the RHS library part (Under steel structures) which gives you greater control of the cutting angle at the ends.
It also has all the standard sizes built-in, so you don't need to reset all the parameters if you change the size for example.
Don't forget if you do use a custom profile, to make it appear hollow you will need to cut a hole in the fill which will then show in 3D also.
Hope that helps!
