Has anyone else run into a lagging issue in the selection of doors on a system running AC12 in Vista 64? I am having a very long delay in both selection and deselection of doors. The weird part is it only lags in the model they are local in, I get no lag if I select and deselect them in a model the other file is hotlinked into. This also does not happen on my other machine that is running XP. However, this model was fine until today. Any ideas?
UPDATE: I checked the back ups from today and last week and it has the same problem with those files. So, it seems to be the machine and not the file. No, updates ran between Friday and today. Also, saved the PLP as a PLN and encountered the same issue.
