Tracker disappearing is only a symptom of a larger problem of loosing several work environment settings. It is not completely random as thera are some conditions in which it happens 100% of the time (ie, every time you drop in a DWG, etc, the WE settings are lost. Maybe also launching a new instance of AC also does it)
This has been going on since AC version 10, which makes me think that if they could not fix it in a version upgrade, a hotfix patch ain't going to catch it either. It is maddening and has been noted here several times before.
Nattering nabob of negativism
2019 MBP
(2022 MBP M1 still in the box)
