Layer Techniques in AC 9 or 10
Hello, if this has been hashed over before, please excuse me... I did a search for layer related info and I didn't see what I was looking for.
LAYERS, whew! That is my weak point in drafting. I am familiar with some publications that deal with it but my question is regarding ArchiCAD's way of offering us access to the layers tool.
Is there a way to have a list of the layers in an open window off to the side that allows you to view the drawing at the same time, then when you click OFF a layer you immediately see the drawing data disappear from the drawing view? Is this called live update? It would make life so much easier. Is there an add-on for this feature?
3 REPLIES 3
Erika Epstein
If I understood you correctly, the "Quick Layers Palette" should do this. It is under :Windows, Palette Display, Quick Layers.
If you select something in a window, the middle section allows you to turn-off the layer of what you had selected.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Burginger,
You are not alone in being 'weak' on layer control. When discussing this with colleagues, we found that the layer of an object is the last thing we check (after line-type, colour, etc.) and often completely neglect!
A feature you may find useful is 'Active Layer' under 'Options'. If you turn this on, you can choose a layer for all subsequent elements (until you turn it off again). So, if you're doing a plumbing layout, for example, you can set the layer to 'Drainage' and then everything will go on it, whether it's a line, an arc, text or sanitary fitment.
- Keith
Keith, thanks I didn't know about that layer control tool. It should be a huge help. Thanks.
