Layer dialog does not adjust to fit screem
My layer dialog window is larger then my PBG4screen and I can see the bottom. How could I adjust it to fit the screen????
7 REPLIES 7
David Larrew
Try shrinking it from the top, then moving it up on the screen, repeat as necessary. Can MACs do that?
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
__archiben
is your powerbook screen resolution maxed out (to 1280x854 pixels)?
if not, switch it to this (or what ever maximum it allows), change the dialogue size and then switch back. . . ?
b e n f r o s t
Dwight
You had this on a larger display previously.
I suggest re-connecting, re-sizing the dialog and hope for the best.
Perhaps a "Detect displays" routine in your display control might see the problem...
I experience this with dialog boxes in Photoshop and others where once disconnected from the secondary display, dialog box positions are wrong.
Dwight Atkinson
"Try shrinking it from the top, then moving it up on the screen, repeat as necessary. Can MACs do that?
_________________
David Larrew, AIA, GDLA"
Yes, good idea but GS forgot to install those buttons in the top left
A New & Reset should also resize this dialog back to the default size.
No, it does not.
_________________
Eric
Dwight
Have you tried plugging in to your larger display and readjusting the dialog there?
Dwight Atkinson
