No opening in 3d
I have placed a double door in a curved wall. The 2d representation looks fine but when I switch to 3d there is no door opening. In order to even see the doors I have to change the 3d swing to something other than 0° and then you see the doors swung open and a rock wall behind them (see example below). Any ideas on how to remedy this?
Thanks
15 Replies 15
David Larrew
Are you sure you don't have duplicate walls on top of each other?
Select just the Door in plan then open the 3D window... Is the opening there. If it is, that's the problem. Delete the duplicate wall(s).
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Only one (1) wall. Any other ideas?
Djordje
Is it a curved wall (one arc) or a series of straight segments, generated by magic wanding and existing curve?
If the latter is true, then you have to redo the wall - you can place a door into any lenght straight segment, AND the rest of the walls will fill in the opening.
Alternatively, the library part might be wrong, even missing the wallhole part. Is it happening with any other wall?
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
It is a curved wall consisting of one arc.
The same library part works perfectly in straight walls. It punches the hole right through the wall like it should.
David Larrew
Sounds like the problem is with the object. Which door object are you using? So I can test a copy on my end.
AC 5.1-25 USA
Pick any door you want. They all do the same thing for me. It's like they won't punch the hole in an arc wall or something. They all work great on straight wall segments, but put them on a curved wall and there's a problem.
I created the wall using the Curved wall construction method. Under that I selected the first option (enter arc wall centerpoint, arc wall start point, arc wall end point). Then select any door and see what you get in the 3d window.
David Larrew
You're right. I've tried a couple of the doors provided with the stock AC8.1 US Library, same result - no opening. I tried one of my own custom doors - it looked fine.
I can't believe nobody caught this bug during the Beta test (me, being one of the testers). I guess not too many testers use the stock library of doors?!
AC 5.1-25 USA
I use stock doors, but I never use curved walls so didn't try that.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
David Larrew
Shame on you, Karl!
We have until the end of this weekend to send a bug report into the 8.1 Beta Team on this!
AC 5.1-25 USA
