rgarand
Wall Cleanups-
Hello everyone,
I am having trouble with the wall cleanups. I have searched through the manuals and the ArchiCAD 8 Training guide and have not found the answer. See the attached screen captures and hopefully someone can help me clean these wall sections up. I have read about the priorities with walls but this did not seem to work. Isn't there some special magic wand routine I can do to clean up walls?
Thanks
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
4 Replies 4
rgarand
Here is the other wall...These seem to be simple intersections...and I missing something?
Robert J. Garand
Djordje
Do your reference lines join? It seems that on the lower left they don't ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
try with "clean wall &beam intersection"and see where is the reference line ...make a jpg and let me see it...
all 3 reference lines must intersect in 1 point... check it !
