2011-04-06
01:09 AM
- last edited on
2023-05-26
03:54 PM
by
Rubia Torres
2011-04-06 01:48 AM
2011-04-06 02:06 AM
s2art wrote:Where is that rule written?
3. Does it matter as no modeled elements should be on the Archicad layer anyway
2011-04-06 03:52 AM
2011-04-06 04:28 AM
2011-04-06 05:13 AM
2011-04-06 09:57 AM
2011-04-06 10:13 PM
zeropointreference wrote:But be aware that these new layer combinations will not be recognised in previously saved views, even if they have the same name. They will show as MISSING.
A hack to fix this is you switch to a combo that has the correct intersection number, then hit new and create a new combo. Adjust that combo to what you need and then hit update. Delete the unused ones as needed.
zeropointreference wrote:Yes. I do the same. I even go as far as changing all elements I need to the Archicad layer and deleting all others, as sometimes the layers are transferred to the new file even if nothing is on that layer. This is most often for things such as window profile details from manufacturers, which generally have only 8-10 layers in them anyway. Not sure I would do this from another project file.
I used to use the Archicad layer myself but now I only use it to move objects between projects so I don't have to worry about layer cleanup afterward.
2011-04-08 11:33 PM
s2art wrote:I don't think this is the case, not in ArchiCAD 14 anyway. It is my understanding that attributes that are assigned to elements are referenced by their ID and attributes that are assigned to views are referenced by their name. So as long as the layer combo name ends up the same, the view will reference it again.
2011-04-13 07:34 PM
