Layer priorities
I find that if I change the priority of a layer, as per attached file where "partitions" have been changed from "1" to "6" and then close the Layers window, when I next reopen the window I find that the "6" (or whatever number I entered) has reverted to "1". Why is this? I am trying to address interference with the partitions by other objects.
1 REPLY 1
If you make any changes to Layer settings you should update the Layer Combination too. Otherwise the next time you select your view it will resort to the way the Layer Combo was set.
