2013-07-07
09:50 PM
2023-05-24
12:45 PM
Rubia Torres
2013-07-07 10:36 PM
2013-07-07 11:06 PM
s2art wrote:
Redefine the View of the elevation in the View Map, by changing the Layer Combination and updating it. (If you're not using a saved view with a Layer Combination, you really should).
2013-07-08 12:20 AM
2013-07-08 12:32 AM
Jonathan wrote:That is only going to update the Plan view.
In the view map select the plan view that was used to create the elevations, turn off the layer called site walls and then
right click the plan view in the view map and go to view settings and get current window settings.
2013-07-08 01:02 AM
