Layouts - how to 'fit in window' in drawing selection frame
I am working on layouts, and have placed views on my presentation sheets. If I change settings, the view often moves outside the viewable area of the drawing. So far the only way I have been able to get it back has been to find it using the layout as a trace reference and manually dragging it back to the right place.
Does anyone know if there is a tool to centre view within an existing drawing frame?
Or do I just have to place the view again?
Thanks,
Check the "Use Drawing's internal origin as anchor" and it will stay in the same place.
Thanks Stuart, but they are already checked. There seems to be something else causing trouble in this file. If I drag more than one view to a layout, they end up scattered all over the place.
I suspect there is a problem with the project origin...
