We value your input!
Layouts
Hello !
Can anyone explain to me what is a layout, where do i find it and how can I organize my plans with this?
thanks 🙂
4 REPLIES 4
Doh, layouts are were you create your blueprints. You find it your Navigator at left, if you don't have this palette, then turn it on under Windows in menu.
There you have something called Layout Book. On your layouts you put your viewsets. A viewset is a view setup of something in your model. A plan, section/elevation, detail or whatever.
ok so far so good. i found this. what is a master layout, a layout and how can i send my plans there?
(sorry i tried with the Help but i couldnt understand)
Masterlayout are your template layout for different papersizes. You are not able to place drawings on masterlayout, you will have to create layouts on the 'directory' above masterlayout section. You find buttons for creating layouts. And right button at your mouse have often the commands you need.
I will recommend : Try and error, the best way to learn is to test all buttons on a software and see what happend
yes you are right
thanks a lot ill try find out how it works
