cculleton
Leaf and a Half/ Double Doors
Does anybody know how to have a double door with two different leaves?
I am able to make them asymmetrical in size but however I cannot find a way to have two different leaves for instance, I want one side to be 800mm wide with a window and the other side to be 500mm wide with no window or detail.
The only workaround I have figured out to this is modelling it using custom door leafs as a single door, however, then it shows up as a single door in plan whereas I will need the two leaves to be portrayed in plan...
Any ideas do let me know,
C.
1 Solution
Rico Suleyman
Which version are you using? The ArchiCAD 24 library has a double asymmetric door which has different settings for each leaf.
I'm using the French version so I don't know if it's included in other versions as well. 
Go to post
2 Replies 2
Rico Suleyman
cculleton
Hey Rico,
Yes your totally correct, I am using the UK version but for some reason no matter what I did it would not show up... I have it sorted now though although I do not know how I sorted it!
Many thanks,
C.
