Length of lines
Ok, so this is probably the most stupid question ever..
I just started using Archicad 11 instead of archicad 9, and I cant figure out how to see the length of the line as I'm drawing?! I know you can measure it afterwards, but this takes a long time and is unaccurate.
In archicad 9 you could press ctrl-r and type in the length that you wanted. How can I do that now??
Thank you!
14 Replies 14
Thomas Holm
ejrolon wrote:
The problem is the "years" part in the comment, we already "Know" but there is nothing wrong to let GS make it easier for new users. I agree that the tracker is not perfect and I have the coordinates on and use it all the time but it can be argued that it has become a "power user" tool. IMO it is easier to press "M" and 2 clicks and sometimes we "older" users have to unlearn stuff.
So true!
David Maudlin
kliment wrote:
And why do you need the Measure tool?!?
Also, the Measure Tool (which I don't use often), allows a quick way to get a cumulative distance.
My 2 cents.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje wrote:
Do yourself a favour and turn the Coordinate and Control boxes on.
Hollah, playah!
(Translation: I agree wholeheartedly sir!)
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
__archiben
ALT+SHIFT. ALT+SHIFT. ALT+SHIFT. ALT+SHIFT. ALT+SHIFT.
it drops the origin anywhere there is a node or assumed node at any time. read the value(s) you want in your co-ordinates box.
it's old school and still the fastest way of measuring anything from anywhere. when i see someone selecting the line tool in order to measure something my skin starts to crawl . . .
~/ben
b e n _ f r o s t
Djordje
There is also Element information ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
