2007-03-12
12:03 PM
2024-07-09
09:51 AM
Aruzhan Ilaikova
2007-03-19 02:10 AM
lukle wrote:It is not possible to "stretch" objects. However if you use a profile through the beam tool, you will be able to do what you want.
The Universal beam I have currently frames a four sided room. If i want
to strech one side out the only way I seem to be able to do it so that the
joins at the corners are maintained is to make the who square ( 4 beams) into an object. Is there any way of streching out one side so that the other two beams strech with it, without turning it into an object?
Thanks again.
Lukle.
