Library Part Maker 26 not cooperating
Dave Jochum
I've downloaded the new LPM (Build 3000) and followed the GS procedures for installing and opening. The template does not show as available to open. While re-installing, I'm warned it "...is already installed." Anyone else had trouble or found the solution?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
Lee Hankins
I’ve got the same issue and reported it to support. They are aware and it’s being investigated. Have you looked in the Archicad templates folder to see if it is there?
Lee Hankins
ArchiCAD 4.5 - Archicad 29 Tech Preview
macOS Tahoe (26.0)
I've always used my own custom templates stored in a custom location, so I'm assuming the LPM and regular Graphisoft templates should be in APPLICATIONS-->Graphisoft-->Archicad 26-->Archicad TEMPLATES? There are no templates in that location--only a text file INFO suggesting templates be stored there.
Dave Jochum
I think it may be related to the same issues as Goodies not appearing, even thogh they are installed.
https://community.graphisoft.com/t5/Design-forum/Accessories-not-found-after-installation-in-AC26/td...
Maybe you need to re-install 26 but do not start it.
Install the Goodies and LPM.
Then apply latest hotfix.
Now start Archicad.
Or maybe you can manually add the menu commands in the Work Environment, but you will need to know what they are and where they go.
