gdford
Library Part Maker - Boolean Subtraction does not work
- I have made an object with the Library Part Maker
- The blue part of the object is made with a column that has a High Building Intersection Value.
- The slab that the object is sitting on has a Low Building Intersection Value.
- I assumed the automatic cutting that happens with the column and the slab would continue after the library part was made.
- but apparently not
- is there anyway to do this with the Library Part Maker??
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
3 Replies 3
Objects can not interact this way.  Once the object is created it's no longer going to behave like the base tools.
gdford
hummm -  from a tool design standpoint, that is a shame.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Convert them to Morphs maybe before saving them as Library Parts?
