2005-11-29
07:43 PM
2023-05-26
03:11 PM
Rubia Torres
2005-11-30 06:35 AM
Thornewill wrote:mike - the line should disappear in elevation if the walls are the same material and coplanar. you will always see it as a contour in the 3D window, but it won't render . . .
Looking for a little help... when I split a wall in plan, keep one part of the wall showing as a solid line and the other part of the wall showing a dashed line, the actual split shows up as a line in elevation. Is there any way to get rid of this? I can get around the problem in elevation by masking the line with a hatch, but when I go to the 3D window the line still appears. Let me know if you have any suggestions for a fix...
