Lines showing between two floors in 3D.
Orji David
Hi everyone,
I use ArchiCad 20 and once in a while when working on multiple floors, I see a line showing between two floors. Please how can I make it disappear?
Erik Bjornhage
  • Is it visible in an elevation view?
    • Check positioning
    • Check building materials
    • Check Renovation Status
  • Is it only visible in 3D window?
    • Check your 3D Style settings if youare always showing contours
Just a couple of things that could be affecting your view
Erik Bjornhage : SwedishChef, INSIKT Digital Sapiens, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
INSIKT : Eriks LinkedIn
ThinkPad P1 G7; Ultra9 185H; 64 GB; RTX 4070 [8GB] : AC12 - future
It is also visible on elevation view
Make sure there are no gaps and no overlaps between the top and bottom heights of the walls.
The surface must line up perfectly (which it looks like they do) and the surface material must be the same (which it looks like they are).
