Linetype (dot) problem
We have been using AC15 on Mac OS X V.18.2. We couldn't see the dot linetypes even if they exists since we installed the program. However, we can see and edit the dot linetypes in the same files on different machines.
I am not sure that i could explain the problem
Looking forward for your helps.
Thanks.
neslihan
1 REPLY 1
Latest hotfix was solved the problem.
