Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Link Footings to Walls
Hello, is there a way to link your footings to your walls? That way, footings would automatically change if the walls did. Thanks.
1 REPLY 1
Have you tried using a complex profile wall with the footing as part of it?
You can even add modifiers in 22 so that you can stretch the size of individual wall instances, rather than duplicating and editing the profile.
