ETSaum
Lock Angle When Moving Items
In all other versions of Archicad that I run (25 through 29), when I go to move an object, the angle can snap to 45 degree increments (as desired) unless I manually enter an angle. Somehow, I hit a key combination that turned this off in Archicad 27, leading to no angle constraints or snaps. How do I re-enable?
All of the Tracker and Input Constraint variables appear to be the same across all versions, but the others have the the constraints enabled still.
Operating system used: Windows 11 23H2
Edward Saum
Windows 11, AC Version 29
edward@fdgarchitecture.com
1 Solution
I don't have 27 on this laptop so these images are from 26.
The settings are found in the work environment.
But it sounds like you have turned your snap guides off.
Go to post
5 Replies 5
furtonb
On a related note, Alt+A locks the movement direction to the vector between your starting point and the current cursor position.
(Alt+X locks the X coordinate, Alt+Y locks the Y coordinate, Alt+R the radius)
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
And to lock direction to any angle, type:
A <angle value>, then ALT+A
Typing A will enable angle value input in the Angle field of the Tracker, while pressing ALT+A will lock the direction to the entered Angle value. For example:
A25, then ALT+A
will lock the direction to 25 degrees. A Linear Snap Guide will indicate it.
ETSaum
Ridiculous Me had indeed accidentally turned off Snap Guides. Additional responses will make it easier for me to do some custom angles in fewer steps as well.
Thanks all!
Edward Saum
jl_lt
Ace
will try this one! thanks Laszlo
