Loosing mesh only in plan view
Dear friends,
You should know whats my problem is, I can see the mesh drawing in 3d but i cant see in plan view. I verify my layer it is running.
Please help me.
4 Replies 4
Is the mesh on a storey in plan that you are not looking at?
In 3D you can see all storeys at once so isn't a problem there.
Thank you for your answer , but it doesn't appear at the storey that was build but in 3d its appearing , any ideas ?
David Maudlin
dedepc:
You can select the Mesh in the 3D Window and check which story it is assigned to. You can also check its Renovation Status to make sure that status is shown in the 2D Window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
The below topic may be of help. It lists reasons why an element may not be visible:
http://archicad-talk.graphisoft.com/viewtopic.php?p=235941#235941
