2007-11-30
05:18 PM
2023-05-25
04:58 PM
Rubia Torres
2007-11-30 06:38 PM
2007-11-30 10:34 PM
Stephen wrote:I had this happen with stairs (disappearing) and composite floors / complex profiles (turning in one fill type). Indeed moving the section marker as described did the job, although it was a temporary solution because from time to time, not knowing the reason, the same problem occured.
This has happened to me, as well. If you move the section marker slightly, the stair will appear again. That's worked for me, anyway.
