Lost my pointer/marquis
Somehow the marquis that goes along with my point and select tool has disappeared. Cant figure out for the life of me the setting that brings it back. Any suggestions? I've also seemed to suddenly lose my ability to do a photorendering projection. Hmmmm...
6 REPLIES 6
Try restarting AC. We've had these (or at least similar) problems at times in the past, and my guess is that it's because of our graphics card (didn't verify compatibility before I bought it). Ultimately I think it's Windowz's fault, but...
Try a restart of AC (didn't require a whole system restart for us) and see if that improves anything.
Thanks, Ill give it a try...
yeah sometimes for what ever reasons...things disappear...or I can't select something...what I usually do is close out and clean out my cache...reboot my machine....and all is fine.....
In This post I made a side note to this problem. Usually occurs after working in the 3D window extensively.
I also get this strange 3D window jaggedness.
I also posted here the same problem.
Like the others I have to shut-down the AC application and then open up again.
Jay
Maybe the newest hotfix (2219) will take care of these issues.
I am not always one of the First to "dive-in" to Hotfixes.
Unless of course, some of the "Top Guns" (Top 10 Posters) say they are using it........
