MEP 27 - The New Feature that never happened
DGSketcher
Legend
Can someone from Graphisoft please step up and own the current abject failure to deliver the renewed MEP Modeller?
Today I joined the many others who have had to return to using AC26 in order to deliver on our MEP commitments.
We all pay out for GS to deliver improvements to AC, yet here we are 7 months later with a key feature broken & software we can't use. Can someone at least tell us what we can expect in terms of delivery of fixing this MEP debacle and when?
It's bad enough struggling with the 3D screen "grey outs", and the disappointment of new features that suddenly became experimental, but finding a fundamental tool is no longer useable... 🙄
157 REPLIES 157
My question is to why MEP all of a sudden is not working correctly in AC27 ? Does it have to do with compatibility issues with acquisition of DDSCad ? We all know about the inclusion of the old MEP modeler into AC24. If still works correctly in AC26 is there another way to go back to that version to use it ?
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
@Jim Allen wrote:
I have come late to the MEP party.
I didn't install AC26 (no point, not enough features to make the ball ache of template updates, libraries, drawings conversion and upgrade of all stations & toolsets worthwhile) so I tried to use them for modelling some simple drainage in 3D in AC27.
Everything seemed to work okay for some simple drain runs. We added just 3 pipe runs, vertical soil pipes transitioning to horizontal drain runs - and built some manholes (anyone planning some parametric models for these?) and they basically broke the whole building model, which was working fine before, even with imported IFC structure from Revit.
The software hung after a couple of minutes. Having to restart the machine because some over-zealous IT security policy has disabled task manager is really no fun. Removing the MEP pipes and replacing them with columns and beams worked fine.
Not a great start - and just 3 pipes caused a catastrophic fail. Same behaviour on Windows and Mac, but at least I can force quit on my Mac, because our IT security Taliban don't understand Macs...
So there's clearly quite a lot of work to be done. I don't know why there wasn't extensive beta testing with users before releasing this.
MEP pipe routing tools are going to be used for the following purposes:
  1. Cabling
  2. Ductwork
  3. Pipework
  4. Conduits
  5. Cable trays
There might be more, but as an architect - pipes and wires aren't my thing.
Each path type has different requirements in terms of things like terminals/outlets, connections, turns, angles, curves and gradients, and different data properties.
Drainage for example needs gradient information, pipework and I would argue it would be useful to have options to display start and end levels as labels. Drainage also needs wall thickness and material information.
I would argue that you need a different path type for each element type, with the relevant properties and parameters built in. You can't easily use the same tool for a cable tray as a surface water drain.
Without knowing what these components do, how they are constructed and drawn, and what level of information is typically required, you can't possibly create toolsets to draw/model them effectively.
You may as well extrude a morph along a path, or use beams and columns with components for the connections and terminals. Routing path tools for these things need the kind of complexity provided by tools like railings, stairs and curtain walls.
A community of beta testers could have clearly defined the requirements, and I suspect parametric GDL objects could have been used. It works with gutters and downpipes. At least there would have been no compatibility issues between versions.
Hello @Jim Allen ,
Could you send me the file in which the crash happened for you? We would like to test it and see what caused that issue.
Thanks!
Balint Kezer
Senior Product Manager
You never know, it might have something to do with wasting resources on Design Guides and AI Visuals, rather than development completion and QA...
Not a crash at all.
In multiple cases AC just hung, unresponsive. I needed to Force quit on Mac, and on my colleague's Windows machine it required a reboot every time because Task Manager is blocked.
We have replaced the MEP components with beams and columns and everything is now back to normal.
Archicad 28 UKI | OS X 14.7 Sonoma
Wait until you see the new AI visualisation tool!
Personally I think it's pointless and produces derivative images. I would rather have had a new mesh tool, or the ability to import dwg meshes as AC meshes, or some more objects., or some fixes for the PV solar panel objects, or fixes to the railing tool for the distortion with multiple curved segments in 3D, or the ability to display SEOs in plan or, or....
You get my point.
The AC27 GDL editor is pretty nice though😀
Love the new GDL editor. For me that saved AC27.
Given the amount of interest in the AI Visuals I'm absolutely blown away by the outpouring of images in the Gallery.
It's a shame there isn't a tumbleweed emoji...
@DGSketcher wrote:
@Balint Kezer I'm wondering if it might be possible click on a brach connection and change it to a different type e.g. from Wye to Sanitary Tee?
Unfortunately in the current released version this is not possible. Do you find this as a usual workflow to change it from one to the other, or is this now just a one of occurrence? I'm asking to understand the priority of this.
Balint Kezer
The reason I'm asking for the file is because without it, we cannot investigate what is the cause of this. I understand that it has to do with the MEP routes and the built manhole, but this is not enough information to go on and we have not received any crash similar to this.
I also understand if you cannot send me a file (e.g. copyright reasons).
Balint Kezer
I can work with the default wye for now. It's just the default/automated single wye isn't always the right solution when joining a branch route. Having made the connection I might want a Sanitary Wye or even a double. It feels like we should be able to swap these around as part of an edit. If I am missing something in the workflow let me know?
Priority for me should be 2D presentation and the labels before this.
Ah - I can do that, I thought you were referring to the crash report files, sorry about that 😀
Happy to send you the model., no problem with this at all.
