We value your input!
MEP AC27
Camu
Good morning, I also notice that in the flexible pipes, I cannot give it a slope. I can only do it in 3D, whereas in AC26 I could give it a slope when traversing.
1 REPLY 1
Camu
Hello, I installed the final version of AC27 and I noticed several problems on the MEP.
1.- There is no longer a MEP label which gives me the slope of my networks.
2.- If I make a personalized label it does not recognize the MEP when I click on it.
3.- Once the slope is entered on my MEP route, I subsequently have no way of checking whether I have set the correct slope, neither on the object itself, nor by label or other means.
4.- The reduction cones between 2 diameters can no longer be adjusted to the water line (see image); it is a reduction to the axis (plan, section).
5.- Vertical vs Horizontal display bug
I notice that on a MEP scan, there is a difference between the vertical and the horizontal, the symbol of the cut element cannot be edited. In fact, in plan it has a red color on a horizontal route (editable in your MEP system choice) and a black color on a vertical route (non-editable). Moreover, when traveling horizontally I can no longer have a drawn line representation to say that it is on the ceiling, the symbol is necessarily displayed in full which adds confusion to the plan
6.- Elbow Display Bug
I notice that on a MEP path (horizontal & vertical) the elbows are displayed on all the floors that the path crosses. While the elbow is only on the ground
