2024-09-25 01:20 AM - last edited on 2024-09-25 02:15 AM by Barry Kelly
I'm using ArchiCAD 28 Technology preview and the first occasion has arisen where I would like to use the MEP tools. There is no separate MEP work environment that I can use. Is there supposed to be a separate WE? What is the best way to learn the workflow and functionality for a MEP Newbie?
Solved! Go to Solution.
2024-09-25 03:25 AM
Yep, that is where it should be.
I would say it is an error in the Intel Mac installation files.
Someone else running that version would have to confirm.
Not sure if this will work, but I have exported it from my Windows version.
Zipped file is attached.
2024-09-25 02:27 AM
So you are saying you do not see this Work Environment?
2024-09-25 02:38 AM
Hi Barry,
That is correct. I do not see that Work Environment.
2024-09-25 02:44 AM
That is strange because it is a default WE and is locked so it can not be deleted.
Can you show your WE settings?
2024-09-25 02:47 AM - last edited on 2024-09-25 02:47 AM by Barry Kelly
2024-09-25 03:04 AM
Interesting.
I am assuming you are on a Mac?
Intel or Silicon? - is that an option with 28?
Maybe there is an issue with the default installation for Mac if that is the case - I have no way to check.
But something you can do regardless.
Press the 'Import' button and browse to where the program is installed (for me it is on my D-drive).
Browse to that program folder and OK.
You should now see a list of available WEs.
Choose the MEP one and import it.
If you don't see it there then I would say it is an error in the installation files.
Somebody else with a Mac version would have to confirm.
2024-09-25 03:12 AM - last edited on 2024-09-25 03:16 AM by Barry Kelly
Hi Barry,
I found the location that I would expect it to be located at, but the WE is not there. See the screen shot. I am on an Intel Mac.
2024-09-25 03:25 AM
2024-09-25 07:27 PM - edited 2024-09-25 08:06 PM
Hi Barry,
That seems to have worked. Now there is an MEP work environment and when I select it the MEP tools show up. (Woohoo!) Is there a good tutorial on the tools? For example, I don't see a way to change the slope of a pipe.
Thank you!
2024-09-26 03:28 AM
I don't use MEP so can't really advise on that.
The way the MEP system works in 27 was changed quite a bit (and not for the better reading some posts).
I think how the slope of the pipes is set is one of those changes.
All I can suggest is to search here and you will find post like this ... https://community.graphisoft.com/t5/Collaboration-with-other/MEP-Modeler-Improvements/ta-p/394951
And of course there are the help files ... https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F085_MEPMo...
I don't see anything specific for MEP in the Learn portal, apart from a mention about it in 27 & 28 upgrade training.
And nothing new in the Archicad YouTube channel.
So if anyone has any links to any MEP resources, please list them.
