MEP excentric transition
Joze Marinko
Hey, it is possible to draw excentric transition with MEP modeler 27? I need upper surface to be on same height but with different cross section.
6 REPLIES 6
Balint Kezer
Hey @Joze Marinko,
Unfortunately it is not possible to do as of now. We plan to make it work for the Route Element in Archicad 28.
Balint Kezer
Group Product Manager
Why so long ?!?
Why do you not make a patch to have the ancien MEP in AC27 ?
Stewie11
Also load the AC 26 MEP library and you can set the item as a plain object.
My advice is that if you use the MEP modeller a lot, forget the AC27 MEP modeller. Go back to ArchiCAD version 26.
That's the $1 million question, but you'll never get an answer. ðŸ˜€
PaulaDale
Any update?
@PaulaDale wrote:
Any update?
Balint said it was planned for version 28.
https://community.graphisoft.com/t5/Modeling/MEP-excentric-transition/m-p/590027/highlight/true#M170...
So until then, it is unlikely you will see any change.
