MEP in 09 ACStart
Can the MEP modeler be added to the 2009 Start editions of AC?
I work for a surveying company now and they would like the field people to be able to model in the field by adding the MEP modeler to Start.
Trying to get them off of Revit.
3 Replies 3
Sorry I'm not much help about mep and start.
Did get my first 3 hrs of instruction with Revit Architecture the other day, and it does, at least initially, seem rather primitive. Good luck there!
Off subject completely.
How was the fall leaf color display in Chattanooga area this year?
I would assume the peak is done for this year?
Bier
Djordje
Check with your reseller.
As you are in surveying - check the Vico software called Survey for ArchiCAD. It works with 11, and can coordinate the Total Station survey points with the model - great help!
In fact, your company would be best off with the Constructor, or full ArchiCAD plus MEP.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Start edition is intended for one-man home offices where teamwork/collaboration capabilities are not required.
Besides MEP Modeler’s aim is collaboration support between disciplines typically on larger projects and that is why these two do not work together.
