Mac option-copy drag and shift-ortho drag stopped working
Has anyone else had this problem?
I have tested other applications and since the majority of Mac apps all work the same, the Mac option-copy drag and shift-ortho drag still work. It is only a AC problem.
I have tried to change the work environment to the Standard Profile 11 but that doesn't help.
I have tried a New and Reset and that doesn't help.
Maybe I accidentally clicked a keyboard command that turns these options off.
21 Replies 21
I have tested it on many Mac apps including other CAD apps like Rhino. The shift and option drag still works on all of those.
Archicad 9 and 10 have then same problem.
So far it seems to be an archicad problem.
unfortunately restarting has no effect.
Here is what I have tried and none of them has solved the problem.
1. tried a different USB keyboard
2. tried the mouse pad instead of a wired mouse
3. trashed ALL the preferences
4. trashed Archicad and reinstalled from disc
5. applied all Archicad 11 updates
Nothing helps. Any other ideas?
Well, its now been 2 days of no work.
I not only have limited efficiency without being able to option and shift drag but without command clicking roofs I can't make them intersect.
I am only hoping that someone can help me or I am going to have to stop working and call my clients and tell them I can't make the deadlines!
$$$$$$$$ help $$$$$$$$$
Eduardo Rolon
Check in System Preferences
Universal Access-> Keyboard
also under
Keyboard and Mouse
Keyboard Shortcuts
Try right Click using a 2 button mouse or using the trackpad the 2+ finger+ click
___
Create a new User Account and see if it has the same problems
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Funny, I was just loging out of my user account when I got your post.
AND...... yes, everything works fine in my test user account.
Now I have to figure out what to trash or reinstall in my main user account.
Any ideas?
Eduardo Rolon
Have you installed any mouse drivers? Specially Logitech's?
Any Norton, Quicken products?
___
It looks as if a preference might be corrupted. Since the new account works then it is something withing your ~/library/preferences folder. You can move all the preferences out of that folder except com.apple.XXX and keep adding them back until you find the culprit.
AC29 US/INT -> AC08
No new mouse drivers.
No Norton.
Yes, new Quicken 2007.
I will try and play with the preference folder..... ugh.
Eduardo Rolon
You can also try recreating your user account in the new one by copying your ~Library/Application Support and your Preferences to the new account to see when it gets frakked.
AC29 US/INT -> AC08
It was time to take out the trash!!
I went thru and deleted everything I wasn't using anymore.
And now its working again.
For anyone else that has this problem in the future, the possible culprits for me were:
JSM Settings for and "EZ Keyboard"
SuperDuper
Remote Desktop
Quicken 2007
Artlantis
Syphone
Bommerang
iShowU
Opera
Little Snitch
Signal
Palm Hotsync
TinkerTool
Missing Sync
I was too frustrated to figure out exactly which one was the issue but since I do not use them then.... whatever! 🙂
I deleted/uninstalled all of these and waaalaaa AC is working again!
