‎2005-07-26
12:34 AM
‎2023-05-26
03:14 PM
Rubia Torres
‎2005-07-26 03:27 AM
‎2005-07-27 07:08 PM
‎2005-07-27 08:07 PM
‎2005-07-28 02:22 AM
‎2005-08-05 12:41 AM
‎2005-08-05 03:06 AM
‎2007-03-02 10:16 AM
Peter wrote:Any news on this? I have a client with a dwg file with solines as te terrain and the nodes are horribly dense which causes AC to stop adding the splines to the mesh after a while, and they have done only half the model.
David,
I did some testing and I now understand why you have to convert
the AutoCad line segments into splines.
The magic wand tool apparently ignores
settings in the left panel such as line length setting
when it is tracing straight line segments with straight line segments.
It just imitates the original chain of lines.
If this true then it is unfortunate and deserves a statement in the wish list.
I can't think of any reason why Graphisoft would think that this overriding
of user defined settings could be a feature.
Do you remember whether this was true
of the magic wand tool in versions prior to AC 8.1 ?
Thank you,
Peter Devlin
‎2007-03-03 04:42 AM
‎2007-03-03 03:46 PM
