Major Railing Bug - Please Confirm
kittonian
Beginner
Spent the entire morning trying to figure out what I was doing wrong, only to find that this seems to be a pretty major bug in the railing tool.
Issue:
Associative railings using panels and inner posts do not respect the "left offset from previous post" or any of the offsets for that matter. Nothing changes.
Workaround:
If you draw a static railing, everything works as it should and all offsets are respected.
I had created custom panels and needed to use the offset values in order to line everything up correctly for the staircase. However, with or without custom panels, this bug seems to be rampant. The moment I drew the railing statically everything started working as it should.
ArchiCAD 25 | Cinema 4D R23
12-Core Mac Pro (2 x 3.46 6-Core Xeon, 64GB DDR3)
OS X 11.2.3
AMD Sapphire Pulse Radeon 5700 XT (8gb)
12 REPLIES 12
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Tincan561 wrote:
Please send me a private email and I can send you a link to the file.
I have sent you a link via Private Message, where you can send the file in for further investigation.
Please let me know once the uploading process is finished.
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Tincan561
Minh: I am still having this problem and it seems to be a major bug with my system and railings. Can you contact me with a private message so I can send you a file.
Archicad 26 Macbook Pro, Ventura 13.6.3
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hello,
I have sent you a link via Private Message to collect the file.
Please let me know when it is uploaded. Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
