Make SEO not active in different Layer Combo's
I have a house that has two elevations and they each have different roof lines. The first is lower than the second. Is there a way to make the SEO from Elevation A not active in Elevation B? If not it should be made a wish!
Thx,
JTC
Jeremy
I am guessing you are meaning two different options for the one house? I don't think there is a way of doing that at the moment, but it is a very valid idea. Maybe a "SEO on/off" button in the Layer dialogue?
A solution you might consider for now would be to copy the Option A exterior walls to an Option B (with different intersection priorities of course) and SEO them with the Option B roof. Not too much drama if its only the exterior walls you need to do this with.
Thanks,
I wasn't sure if this was possible. I appreciate the input s2art and the helpful idea.
Thx,
JTC
