Making 3D mesh - please help
Hi everyone.
Is possible to make 3d mesh from this file?:
http://dl.dropbox.com/u/67741662/ales-1.dwg
I dont know how to do it
Is there any tutorial on web?
Thanks for help!
13 Replies 13
Martin Jules
Mentor
andro55 wrote:
And this is the add-on:
That info is very helpful for me. Please tell me if this add on can be downloaded on both iMac and PC.
Martin Luther Jules
AC 10-29 (Full)
Asus | 64 GB RAM | Windows 11
could you please repeat all of that for users who just do not use AutoCAD alot? I cannot Install the Add-on, so my problems began really early 🙂
Thanks
You don´t need to install nothing!
1. You need a ".lsp" add-on (export_survey_3D_points.lsp) for AutoCAD (or other compatible CAD program with a support for AutoLISP).
2. Load the add-on.....type this in Command line: appload export_survey_3D_points
3. run it.....type izvozgeod+Enter and the program will export 3D points to a .toc file. Next rename that .toc file to .txt file and open it in the Notepad. Delete all points without a "z" values, then save.
4. In ArchiCAD make the Mesh.....Design/Place Mesh from Surveyors Data!
(select the .txt file that was allready exported from AutoCAD).
Martin Jules
Mentor
Many thanks !
Martin Luther Jules
AC 10-29 (Full)
