Making stuff visible on other plans!
I have some walls I would like to seen in the upper plans. With slabs or meshs thats easy, there's an option where you can select what you want to make visible on other plans. As for walls, this does'nt happen. What should I do?
Thank you!
6 REPLIES 6
adzik
One way is to create "dummy walls" with a height of 0.0 meters on the story you want them floor plan that you want to show them.
You can also just draw the walls with lines/fills.
Running ArchiCAD 23 INT.
David Maudlin
in.volve:
You will need to familiarize your self with the Floor Plan Cut Plane, this is the method Graphisoft has developed for showing walls (and other elements) accurately on multiple floors. The wall Floor Plan Display will need to be set to something rather than Symbolic, the settings you need depend on what you are trying to achieve, the Floor Plan Cut Plane is a cut through the plan like a section is a vertical cut through the model.
600
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I work with the portuguese version so I try to translate menu names as best as I can! Where can I find (in what menu) the"Floor Plan Cut Plane"? I refuse to believe that the best way to this is creating dumy walls! Why is'nt it like the slab tool?
Very strongly advise against using this 'solution'! Zero height walls cause export problems with Artlantis and perhaps other software.
Floor Plan Cut Plane, or stacked drawings, are recommended solutions.
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
Thanks for the help guys!
I made it through "Floor Plan Cut Plan", it looks great now!
Thanks again!
adzik
I wasn't aware of that, thanks for the tip 😉
