Masking Fills
I am having difficulty using a fill to mask extra lines in my section views. I have no problem getting fills to mask in floor plans but I can't seem to get the same fill setting to mask in sections. The section is set to infinite distance so I can generate interior elevations at the same time (small project, two birds...one stone).
Any help I can get would be much appreciated.
Gary Bley
4 Replies 4
TomWaltz
What's the problem you are having? What about it is not working?
Tom Waltz
Tom,
The problem is that once I put the fill in place, the lines behind it won't disappear in section. As I said, I can use fills as masks just fine in plan, but in section the target lines remain visible.
I keep thinking that it is a view depth issue, but I have tried changing the view depth with no luck. Empty fill, solid fill, transparent background, window color background, display options....nothing seems to work in section.
Perhaps a step-by-step listing of the proper settings would help.
Gary Bley
TomWaltz
Make sure you are bringing the fills forward, not sending the model lines back.
Tom Waltz
Tom,
Thanks. That appears to have done it, although I couldn't just bring the fill "forward". I had to bring it to the front. I love the subtle nuances of this software.
Gary Bley
