Masking contour lines
On a floor plan View, is there any way to "mask" the contour lines showing within the building footprint.?
I would like to display the terrain up to the building edge but not showing inside the building.
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
If your building is a slab then turn on the cover fill and bring to front -this may affect other plans though.
I would just add a separate fill or model the perimeter of your buildings with fills.
You may need to adjust the display order.
